Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
It doesn't have to be a ray traced game though. Imagine a VR game using RT cores for better directional sound. That would be kind of rad.
"Most of Nvidia’s current plans for the Tensor cores revolve around neural graphics. However, the company is also researching other applications of deep learning on desktop cards. Intelligent enemies, for instance, would completely change the way gamers approach boss fights. Speech synthesis, voice recognition, material/art enhancement, cheat detection, and character animation are all areas where AI is already in use, or where Nvidia sees potential." From a Tom's Hardware article covering Turing's launch. There are a variety of things they could do.
I've done the new benchmark!
In Daz 4.12.0.86 or something like that:
Basically, the 2070 Super is the best buy at the moment for Iray rendering.
It should be 65% faster than my 2060, and 40% faster than a 2060 Super.
Current prices here:
So +34% in price for +40% in Iray performance. I think it may be worth it, but this is not a good month to buy GPUs!
Wait till after Xmas at least. Sales are far more likely then.
In the end, I found a RTX 2070 Super from MSI at 530€ and I ordered it!
Let's see if it will achieve those 6,2 iterations/second in my system! :)
what is the link for the "new" benchmark? I have an MSI 2070 Super myself. It would be interesting to see the results
As outrider said, it's this one: https://www.daz3d.com/forums/discussion/341041/daz-studio-iray-rendering-hardware-benchmarking/p1
Cool, I'd like to know the result :D
I'm not sure of all the readings, or where to get them, but , if I did it right,
1800 iteration /. 5,min. 23 second Total Rendering Time, I get 5.57. I dont see anything called Device Render Time in the log. .. not sure what any of it means, and no idea what the second part, loading time, comes from.
I'm also not sure if I have DS set up as far as optimum from my card, or even if the card is set up correctly. I'm not into all the tweaking. I usually hit render and go for it.
I wasn't able to find that part either.
Apparently you should close Daz immediately after the render.
It's still an impressive result!
Thanks for taking the benchmark :)
So I finally got that RTX 2070 SUPER.
It's an MSI Ventus model.
If you're interested, it's mostly plastic outside (even the backplate), but it's pretty big and heavy, so I guess it has a nice cooling.
During rendering it goes up to 80°C (keep in mind that I have a small crowded case), and the fans can get pretty loud. They don't look top-quality to me.
But in idle it's pretty silent.
I'm testing it out.
The expected performance gain should be around 65%.
I've used an actual render from my current comic:
I've also used the benchmark thread, and there I got 5,82 iterations/second, versus those 3,75 that I used to get with the RTX 2060.
According to that, it's a 55% performance gain.
I hope someone will find this data helpful.
Thank you all for the help.
