Default Camera deleted?
I'm not one to create a lot of cameras - in fact I mostly make do with the default camera and the perspective view (the latter because it doesn't affect the timeline). However, I've been making a lot of images as if they were taken on an iPhone so I created a camera with a suitable aspect ration and saved it as a camera preset. The problem is that when I load that preset it seems to delete my default camera (or replace it). Is this normal behaviour or just recent?
Seems there is no way to add back a default camera either - I just have to create a camera and give it a name and apply the default settings.
  • barbultbarbult Posts: 26,613
    edited December 2019
    If you hold down the Ctrl key when you load the camera preset, you will get a dialing  dialog asking whether you want to replace cameras or add one.
    Edit: stupid spell checker!
    Post edited by barbult on
  • marblemarble Posts: 7,500
    barbult said:
    If you hold down the Ctrl key when you load the camera preset, you will get a dialing asking whether you want to replace cameras or add one.
    Ahh thanks. Simple when you know :)
