looking for a "auto" fix" for outfits
hello people, i'm here to ask if anyone know if we have any "autofix" corrective morphs, i've already saw a lot of "corrective morphs" but most of then are "manually and you need to do all the job for fix and while it can be good and give you more "freedom when trying to fixing things" it also can be very annoying when you are looking for more "fast things", then i would like to know if anyone know any of the "corrective"/fixes scripts, if have anyone more "automatic", like when you use the autofit a addon/script which will improve it making the prop conform in a better way or to avoid pocking issues, for exemple the CC from Reallusion does have a script which autoadjust cloth layers it's not perfect but already a good start you have to make some tweaks here and there, then i would something like that a script which whe you select or the character body or the outfit it will try to autofix any bad fit or if possible adjust how the cloths are stacking in the way you want, or something like that or maybe in a future version of daz would be good to improve the "autofit" how it works.
Smoothing Modifier?
yeah, but that won't work for the OP since they use DAZ assets outside of Daz Studio
Is there not some equivalent in their program of choice?
I've gotten into the habit of using Daz Studio just as a JCM/Autofit factory. Once all these wonderful technologies are applied, I export via Alembic for everything else.
Edit: Intend to post for other thread and accidently posted here.
