Posing with Aniblocks
taraque2013
Hi, community! I was so proud of myself yesterday. I looked up how to make aniblock poses and then read how Jaderail did it. But now that I have my aniblock (which is a female falling down) she moves too slow. I moved the speed to 500 (the max) and it is still too slow. I thought to delete some frames in there, but it didn't let me. How do the pros do it?
In the Aniblock you have a speed setting when your in edit mode it defaults 100%. Change that to a higher setting. You block will shorten as the speed increases. You should save the fixed AniBlock as a new block once done.
If the above was the way you did the edit, I'm afraid your only option is to make the Aniblock over again and keep the speed of the motion in mind as you create the new one. None of us get it right the first time, I know I didn't. Or the second or the....
Thanks, I did do it the latter way. I'll remake the block
