Quick Question
TrishTrish Posts: 2,625
made a terrain....saved it in obj format ...opened studio went to import object...it shows this screen ...I click accept.....and it does nothing else......what am I doing wrong?? thanks Trish
    What app did you create it in?
    Did you at least assign one material to the obj in that app?
  • TrishTrish Posts: 2,625
    It is created in Bryce and yes it was exported with the materials...everything is on my desktop....
    82 x 612 - 27K
  • Richard HaseltineRichard Haseltine Posts: 109,650
    edited December 2013
    Do you see anything if you switch the viewport to wireframe? Or are you saying it freezes with the dialogue boxes in place? If so, how big is the OBJ file?
    No but I will try that and get back you...Thank you Richard....it doesn't freeze just doesn't show anything was imported...I will try wire frame mode ..I just thought it would come in and be visible with materials...maybe not
    Post edited by Trish on
    There is something that you have to do with a terrain in Bryce if you want to export it out, but as I have never done it I can't remember what it is.
    I am such a Bryceaholic that I only ever work in Bryce :roll:
    no wire frame does not make a difference.....well what program do the content creators use to make a terrain??? I know chohole me trying to do it backwards just isn't working...LOL oh it exported out alright its on my desktop DS just can't see it ...LOL I need to stay in Bryce...and leave DS alone I guess....I sent a PM to Horo....Trish
  • JaderailJaderail Posts: 0
    Trish try this. Remember Bryce and DS default to much different Size of default mesh files. Make a Very simple SMALL item in Bryce, be sure it saves out of Bryce in OBJECT format. When you Import set the Import option to DAZ Studio defaults. It should load in VERY small but load. Once you get one loading Import as Bryce settings and It should load properly. Your Bryce Terran could be too large for DS to load as a single object, your first one.
    Jaderail: ok now that is a good idea...ok so far I made a square box pic 1......exported as object.....tried each one of these options to import into DS.....nope ..Studio is not having it....cube size is 997 bytes...what size is a unit..in DS... never mind I see 1cm
    937 x 624 - 167K
    1270 x 579 - 18K
    ok been experimenting....can't even send anything back to DS that was exported from DS tried the useless bridge half of the object only appears...Thanks anyway way too much trouble for my mind....Trish
    Well it was the only Idea I had. Let me test one of my Bryce items....
