FBX to Poser
Alric
Is there a way to bring FBX files into Poser Pro 2014. I have some rigged models in fbx format that I would love to use in poser. I can get them in as OBJs going through Carrara but of course I loose the rigging.
the only way I know is to import the geometry rig it in the setup room in poser export a bvh from whatever app you are using to export fbx if you are trying to use the animation open the bvh as a text file and match the bone names. I am sure there is probably an easier way .Hope you get the solution you need happy 2014 to all !!!
