Avatar.
Cat_Dancing
I've long had a cat for an avatar but because of the size of the image only it's right ear shows. I now have a image of the correct size so would wish to change it. How do I do that please? Thank you
Click on the gear icon in upper right corner, then your name. On the next screen click on the lower gear icon, edit your profile. Then change my picture Sorry, you want edit my thumbnail, you can drag on the box to select
I thought your peeping cat was deliberate and very arty
Hi Wendy - No, not so clever unfortunately. The whole pic shows a black & white cat who is dancing, very KOOL. Luv cats too! Must go ahead and have a look at your 'Madcatlady Channel' You have a nice day.
Hi Wendy - Dancing Cat now sorted.
are you certain it's dancing though and not just marking territory with a spray
Ha ha! Plus the expression on his face. "You thought this was yours? Just gimme a second..."
Hi again Wendy. No I'm sure he's dancing, the original image comes from a gif file, although, on reflection, he does look as though he's straining. Maybe wind is the problem, should I change my handle to 'Cat_Farting'?
Another question whilest I'm here. Is there a DAZ re-set button that takes DAZ backc to it's original state? I've been 'clicking' on things to see what happens, I call it learning. I have now lost my blue background screen, the one with the grid on it that appears when you start DAZ (See pic) Try as I might I cannot recover it, iin fact I think I've made things worse. HELP!
You can go to window > panes > viewport, and that will bring the window back. If it's not docked at the top when it loads, grab it by the tab and drag it to the top tabs. Or if you want to just reset to a default, window > workspace > select layout and choose one of the ones in the dropdown
I know this is an old thread, but I can not get the "Click and drag across the picture to define your thumbnail" feature to work. All that is happening is that the picture is moved about with no effect what-so-ever.
I have tried in a number of different browsers, so apparently that was not it.
If someone can help me out here, I would appreciate it.
Later edit:
Never mind - I just changed the picture cropping seeing that the "drag to define thumbnail"-feature apparently doesn't work.
