Country Kitchen
debb6425debb6425 Posts: 0
Hello,
I am having trouble with some of the parts of Country Kitchen. I have been back and forth checking it in notepad++ and everything. They will not load in Poser 7, and P8 has no library now due to the recent Windows update for IE11. Anyhow, the ceiling beams, the vent and the cabinets will not load at all. The hutch loads, sans doors and drawers. I am at a loss as to what is causing this. The Cr2's point to the correct obj's and jpg's... I cannot figure the issue out. Has anyone else had a problem with this?
Thank you for your time and understanding.
Debbie
    debb6425 said:
    Hello,
    Debbie
    i think there's a patch out to fix the ie11 thing. stickie over at the rendo poser forum
    hmm, i still have p7 installed, ...
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,466
    it gave me the same issues in Carrara
  • debb6425debb6425 Posts: 0
    Thank you for the advice, Misty Whisky; but the patch is only for P9. They don't do anything for P8 anymore. Anyhow, that is not what I need help with. I need to know if anyone has figured out how to get these parts of the Country Kitchen to load, and be visible... Thank you again, Misty Whisky. I wish they had a patch for P8 :)
    edited December 2013
    Microsft issued a patch that removes the IE 11 update from your computer and stops auto updates from doing any IE 11 updates. THat allows P8 to work again, as long as you don't need to have IE 11 for any reason.
    http://www.microsoft.com/en-gb/download/details.aspx?id=40722
    Post edited by Chohole on
    I only care about getting the Country Kitchen to open in Poser 7, since that is what I use... I hardly ever even open P8... I don't wish to roll back IE. But, Thank you for the suggestion. I've already investigated that issue. Thank you for these suggestions though.
    curious if anyone figured out the country kitchen thing?
  • JGreenleesJGreenlees Posts: 2,249
    The props are loading in Poser 9,2012,2014 i will have to find my disks with poser 8 and take a look (hopefully can find it today have about 300 disks to go through)
    was just thinking, later poser handles n-gons better than p7. any chance the kitchen has ngons in it?
    how does cararra handle ngons?
    oh all the bits load ok in carrara, just not in place
    the cupboards walls sink stove ok but the hutch and addons all load in the same spot outside the wall, not in situ
    all on top of each other, plates drapes basket doors etc
    maybe it's the unit of measure / scaling thing again?
    someone said ds is set to centimeters.
