Shattered Released + Freebie office block (Commercial).
Dogz
http://www.daz3d.com/shattered
Shattered is an extensive Prop set of DAZ Studio focused on broken glass. There is no opacity or displacement map trickery here, instead every crack, hole and fragment is presented in actual 3D Geometry.
The set consists of nine Panes of glass, with different dimensions and shatter break up effects based on different glass types, to compliment these there are also five 'flying' glass debris collections and five 'ground' glass debris collections (Making 19 Props in total).
Each prop contains many morphs, the panes each have 2-3 basic shatter morphs and 20-30 Morphs to create an assortment of 'holes'; some of these combinations are already set up as shaping presets. The debris collection props can be used for more customized shatter effects, they also have several morphs each to r-arrange the formation of the glass fragments.
There are six Glass materials, including tinted glass and mirror glass.
Finally there is small selection of 'dummy glass' props. These are simple box panes that use the same material zones and shattered glass, they can be used to create any undamaged windows with matching materials.
Also links to the Office block from promo images can be found here (Freebie): http://www.daz3d.com/forums/discussion/34767/
Enjoy.
Unbelievably USEFUL and much needed! Thank you for making this.
Can you make a set like this for breakable walls? I certainly need one made of wood.
Thank you so much for having made this! Wasn't planning on spending further money, but this shall be just tremendously useful.
Very much needed, thanks!
It is one of those products that makes you shout "Yeah baby", ok it did me. :)
This is something I have been looking for for a while. Oh my poor wallet! Thank you so much!
Very nice!!!!
Did you hear a Sonic boom? This thing hit my cart the moment the Store set the image on my screen.
Dear DogZ,
Is that possible to break a car's windows with this product?
ex. Morris
http://www.daz3d.com/sports-car-morris
Or I need to replace the window before break it?
Is there any tutorial on how to break a car's windows with this product?
Leo, it is maybe possible that you could use a deformer or two to make this glass "fit" the car window but not likely...however, if you have a program like dress shop, just cut some cracks in the car window and make your own cuts, or use primitives, or use transparency maps, or postwork, a lot of options....
Dogz, I am hoping this product will be in march madness as I was broke when this hit the store.....
Thank you,belovedalia.
I still have a lot to learn ... and I do not have "dress shop" by now... and I am not familiar with the "dress shop".
BTW, the "shattered" was in March Madness...
Sorry, dress shop is this: http://www.daz3d.com/dressshop
I love it because it lets me cut stuff up just by importing the obj and drawing lines on it pretty much!!! same as making clothes but I use it to make a ton of weird and wonderful odds n ends. Heh! It's totally addictive!
You would need to replace it, but the rounded off corners of the window frame on that car would be a problem.(the shattered panes would poke out)
Best solution would be to used a shader or material (as suggested by Belovedalia) to make that window appear shattered, although you could use one of the debris props in 'shattered' if you needed the effect off glass pieces flying.
If I was doing the same task using DAZ Studio's default renderer (3delight), I'd be inclined to do a spot render of the windscreen to overlay in post - that way you can mask/delete any pokethrough of glass at the rounded corners and merge layers together when happy with it..
Thank you,DigZ.
BTW, the shattered is a good product.
It is already on my whish list, I am just waitting until it GO MAD!
BTW, I need "Mac" version, maybe I need to wait until next Mad.
