Has been an error...
ssf16ssf16 Posts: 0
edited December 2013 in Bryce Discussion
Hello
I have used this tutorial for Brice 7 install, but have this error :
(View attachement)
I install Bryce_7.1.0.109_Win32.exe, and the error message come when at launch BryceProContent_7.0.0.19_Win.exe
Sorry for bad english
Post edited by ssf16 on
  • ssf16ssf16 Posts: 0
    Up please ^^
  • HoroHoro Posts: 11,445
    @ssf16 - Get this PDF http://www.horo.ch/docs/mine/pdf/BryceContent_v4.pdf. It tells you, how to install Bryce and where the content belongs.
    I just uninstall everything to reinstall from the explanation of Pdf.
    I also check the paths of access, they are good.
    But the result is the same.
    The problem occurs when installing Pro-Brice-7 content.
    I take screeshot from path
    1600 x 900 - 223K
    It says (in english)
    ''C:\Program Files (x86)DAZ 3D\Bryce7/Uninstallers/Remove-BryceProContent.exe is not recognized as an internal control or external executable a program or batch file. The application will exit now.''
    Are you trying to install or uninstall when you get that error.
    Post edited by Chohole on
  • TrishTrish Posts: 2,625
    I wish I could help you .....here is what mine looks like
    200 x 529 - 55K
    Post edited by Trish on
    ''C:\Program Files 9x860DAZ 3D\Bryce7/Uninstallers/Remove-BryceProContent.exe is not recognized as an internal control or external exectuable a program or batch file. The application will exit now.''
    I trying to install BryceProContent_7.0.0.19_Win.exe.
    Did you tell it to create an uninstaller when you tried installing it? Maybe try not letting it do that.
    Also don't let it replace any content. You want both content files installed.
    @ssf16 - If no better ideas come up, get the zip for the Mac, unzip and copy the content as showed in the PDF. The content files are the same for Mac and PC. What you have in your Bryce folder is correct. C'est bête si ca embête.
    This is good, I found.
    When he asks you uninstall a previous version before installing it, I say no.
    Bizarre, other versions I had no problem.
    Thank you for all
