How do I remove these veins
I used the "add veins" software.... how do I get to an area where I can remove them... There is no preset that removes them automatically. and I can't do the ctrl-z because the edits are too far back.
Parameters or Shaping Tabs they are controlled with a morph dial, set them to 0% on all areas needed.
That''s the promblem ... I have checked many times over and I still dont see the sliders?
Which Item are you using? That would help, I do not understand exactly what you mean by the ADD Veins software. I have many items that can add veins. I thought you were talking about the new Free item.
Not the free one... but " Add Some Veins"
I tried to find it thru "surfaces, shaping, parameters"... etc. but I can't locate anything that touches it..... on a Gen2 figure
Surfaces TAB its the BUMP settings, says so right in the INFO page of the item. Also check the Displacement settings just to be safe.
http://www.daz3d.com/add-some-veins
Wow!... (really??) ..... I feel dumb.... I thought bump would only control if skin was raised not coloration....
If you Applied the FULL overlay (they are LIE) overlays your ONLY option is to PUT a new SKIN texture on your figure. That will clean all the OLD textures you have applied. You asked how to remove the Veins not how to replace the textures. I was only trying to remove the Vein part as I thought that was what you had asked for.
