Big Heads
Recently purchased Aiko 4 Toon and Hiro 4 Toon. When I inject the morphs Aiko 4 and Hiro 4's heads grow to ginormous proportions.
How can I fix this issue?
Thanks in advance.
Thanks in advance.
How are you adding them...to a 'base' character or to an already loaded Aiko?
Make sure you have only one Runtime with a "Runtime:Libraries:!DAZ:Victoria 4" folder (and the same for Michael 4).
I'm loading Aiko 4 first, then selecting the body, then going to the pose folder and clicking on the injection.
You should Select the FIGURE in the Scene Tab then Inject the morph. And as Mike points out the Morphs must be installed into the same location as the V4, A4 figure and morphs are. And the Same for the M4, H4 moprhs.
