DAZ Backrgound images
I was wandering where would you put daz background images? thanks in advance for yalls help.
top left of screen click edit... backdrop.....set your render size first.....it will make it come up at the render size.....then go to image... browse...and find the one you want....hope this helps Trish p.s. If you mean install use the DIM
... or create a plane, rotate 90 degrees over the x-axis, translate backward, go to surface tab and put the image of your choice in the diffuse channel.
Or, if you want even more control, render to .png, put a background image afterwards in your image editing software.
(but I also wonder if that is what you mean)
I really appreciate the help yall thanks
