Dust Prop
Just as the title says. a simple prop to add a layer of dust to other objects. The scenes I'm planning in the future will be in an abandoned house and using photoshop to try and add a layer of dust throughout all the images is going to be way too much work. even better would be a dforce prop so it can settle nicely where it is intended.
  • To get dust on things I suspect you might be best off draping a dForce plane and then using a shader to apply opacity, and a dusty normal/colour, to the level surfaces - the shader from TerraDome 3 might work for that.
  • 3Ddreamer3Ddreamer Posts: 1,347
    I can't vouch for it yet as I only bought it in Fasgrab yesterday and haven't downloaded it yet, but...
    https://www.daz3d.com/iray-surfaceworx
    Just from the looks of the images of the car comparison on the product page that is close to what I am after. After you tinker with it a bit, could you post an update if it will be possible to make a consistent layer like in the image I posted?
    This is the best I've managed. It certainly suits my needs, but not sure about yours - not the flat layer of dust, more patchy. It utilises overlays so you could maybe make your own texture
    1058 x 873 - 1M
