Simple Wireframe
kiekelly1976kiekelly1976 Posts: 0
Hello there,
I'm new to DAZ 3D and wanted to ask a basic question
Is it possible to simplify a model and reduce the number of Polygons ? So that it has far less Face? and Detail?
I'd like to work with Low Poly Figures is possible?
Attached is a sample
Thank you
  • Miss BMiss B Posts: 3,071
    If you have the latest version of DAZ Studio, there is a plugin for it called the Decimator.
    You can see it here  --> http://www.daz3d.com/decimator-for-daz-studio but be forewarned, it is expensive.
    I don't believe there is any other way to accomplish what you want.
    That said, however, there are LoREZ characters in Predatron's store that won't be as expensive, and might be just what you're looking for.
    http://www.daz3d.com/predatron
  • Dream CutterDream Cutter Posts: 1,224
    Meshlab (free meshlab.org) has a filter that reduces quads. Select polys then apply the Quadratic Edge Collapse Detection from the Filter menu.
    There are many other options within standard modeling apps like Modo, ZBrush and 3DCoat. There are also dedicated decimators like http://www.atangeo.com/
  • kiekelly1976kiekelly1976 Posts: 0
    Wow, thank you both for the quick response - Much appreciated :)
