How can i export genesis to Zbrush with the morphs?
When i try to export genesis to Zbrush after using some morphs i find my self in zbrush with the original genesis clean of morphs figure.
how can i use the morphs on genesis and export it to genesis with the morphs applied so i can edit them ?
and if try to export the figure from daz as .obj and imoprt it in Zbrush and then use it back in daz, i lose every thing clothis, rigging, and morphs.
so, what can do ?
Don't you have the GoZ plugin for DS installed?
It should be available for free in your My Account area under Product Library.
I don't use ZBrush, but I imagine that is what it is for.
You export with open verticies intact and in ZB you also do same and when sculpting the dont sub divide mod never add or reduce polys because the count must remain same to reimport back to DS. GO-Z helps but not essential.
Thanks for the help guys I got it now.
