Animation with dynamic clothes.
I am starting to play with animations. I have noticed that if you use dynamic clothing or cloth .. when you key a frame the dynamic materials revert to the cleared position. Is there a way to use dynamic clothes in animations? A dynamic prop .. like a pillow .. seems to stay fixed as long as it doesn't move during the animation, but clothes immediately revert to the cleared position.
  • Richard HaseltineRichard Haseltine Posts: 109,577
    Changing the figure clears the drape - if it didn't then the drape would almost certainly be wrong at that point. Ideally you should get the animation as right as possible before draping, to reduce the number of redrapings required.
