Fix a facegen head to V4 body
hello friends..I have made a head in facegen ... now how can i attatch it on V4 body perfectly ...is there any software to fix it...?
What you're asking 'as is', is not possible.
To morph V4's head, you'd need to import into it via the Morph Loader, a morphed V4 head .obj file. And then create the morph in the usual methods. [route varies per edition of D/S] AFAIK, this requires having purchased both FaceGen and the customizer plugin.
If you haven't purchased all that; with the free FaceGen and the less expensive exporter; one can morph Genesis ;-)
Morphs for V4 also exist in the store for Genesis if you want to mix some of V4 in with your work ... Hexagon can also be helpful in said process.
there's a "one time" use free trial for the customizer plugin and there was also a free trial for the exporter.
I only have the Genesis exporter but I do believe the far more expensive (by about 3X than the genesis version exporter) facegen customizer can be used on an exported V4 or other head mesh.
I know some iClone content creators have used it.
Another way is to export all the visemes and expressions as obj meshes and load them as morph targets on an expressionless imported facegen obj head to make your facegen head object animateable then frankenstien it to another figure hiding the figure's head and adding a wide choker, scarf or turtleneck collar to hide the join.
If really keen one can convert the obj to a figure, save it as a cr2 and use mimic pro to create a lipsync dmc but honestly just getting the $99 ( I still believe it is that price) facegen Daz Studio 4 genesis exporter is much easier!!!
Which modules and licenses do you have? I can walk you through the process if you have the modules and the licenses.
