Daz default install location?
Hi Im trying to figure out what Daz's usual default location is. Im trying to use daz to blender importer. Blender asks for library path but I've installed Daz on a D drive instead of C. So whenever I try import it just gives me an error. By the way this is from Diffeomorphic.
So you want the content location? The defaults are, for DIM installs on WIndows, C:/Users/Public/Documents/My Daz 3D Library/, for DS saves it's Documents/Daz 3D/Studio/My Library/, and for Connect I think it is Documents/Daz 3D/Studio/My Daz Connect Data/. Documents will be whatever the system Documents folder for your profile is.
the default installation for the program should be in the program folder on the C drive either prog files for 64 bit .. or prog files x86 for 32 bit
but yep you can run the program itself from any drive you have the Daz folder that matches the one in the program folder on.
