HDRI map light intensity
I used HDRI map (sky) and now my scene looks a bit overlighted. Since i can't see the any "skydomes" in the scene tab i don't know how to chage intensity of the light. Does anybody know?
And how can i delete the HDRI map if i need?
Render Settings>Editor tab and look in the environment group on the left. That will also let you remove the map (select None from the list) though if you do that it will switch to Sun/Sky mode - a better way is to set the Mode to Scene Only, if you want to use in-scene lights.
Thanks!
There's a setting on the same page for dome light intensity. 1 is default. I've gone as low as 0.05 for scenes.
