Why don't some objects fit the model
There could be a lot of possible reasons, some examples would help to narrow things down.
Difficult to answer without more specific data.
But the two most common general answers are.
1) The item isn't designed for that figure.
2) The figure contains morphs not supported by the item resulting in poke through. Adding a smoothing modifier and increasing the smoothing itinerations often fixes this.
Or when loaded it didn't automatically "fit to" the model and you have to manually do it.
Very True. :)
I leave video.
https://youtu.be/ytTp9gzjApQ
The issue is that you are not setting the original figure (Victoria 4) the the shoes were made for in the AutoFit dialogue, so it doesn't know what the starting point should be. Assuming that the figure is the Stephanie 6 (which means Genesis 2 Female) character selected in the content pane on the left then you will need the Victoria 4 clone shape for Genesis 2 Female, from the store, or you will need to load Genesis, load and fit the shoes - selecting Victoria 4 as the original figure they were made for - then fit those shoes to your character - selecting Genesis as the figure to be converted from.
