LoveChild - Photo Morphing Software crashing issue
Just bought this program to try it out but it keeps crashing on me. When I check for a solution it tells me that Morphing failed on python side, whatever that means. Here's some further details:
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    faceMorph.exe
  Application Version:    0.0.0.0
  Application Timestamp:    5d24a292
  Fault Module Name:    dlib.pyd
  Fault Module Version:    0.0.0.0
  Fault Module Timestamp:    59a362a1
  Exception Code:    c000001d
  Exception Offset:    00000000001a2709
  OS Version:    6.1.7601.2.1.0.256.1
  Locale ID:    1033
  Additional Information 1:    b8b2
  Additional Information 2:    b8b2d4db20fd052f372bd7eea79962b4
  Additional Information 3:    a900
  Additional Information 4:    a900be5ab634e965906d846437c43f36
Has anyone else had a simular issue? Any help would be appreciated.
  • Okay. So I tried the program with another computer and I got this message.
    Python morpher error: the specified executable is not a valid application for this OS platform.
    Is this a windows 10 program?
    LoveChild is a Windows program. Can you pls. give me the specific machine and operating system info via our Tech Support email: [email protected]?
  • sjjesso_78ca0e6d0csjjesso_78ca0e6d0c Posts: 79
    edited November 2019
    Acer 5552-5686
    Window 7 Ultimate service pack 1
    The other laptop I tried it on was a panasonic toughbook Running windows 7 pro Both are 64 bit Operating systems.
    Post edited by sjjesso_78ca0e6d0c on
  • Been going back and forth with support. From what I can Gather this program does not run on Windows 7 so be warned if you plan to buy. Also for you Windows 10 users out there I would very much like to know if any of you have been having the same problems.
  • OK. The issue is WIN 7 SP 1. LoveChild uses Python that requires a later OS, preferably WIN 10. Can you pls. try to install on WIN 10?
    I have tried it on windows 10. The results are the same. I've tried everything that was suggested and the results are the same. I even tried the two examples that were sent to me and the results are the same. There's a Python Error. This program will not work for me.
  • send me an email to [email protected]. We will send you a replacement part.
    Message sent. Though I have my doubts that anything can be done to get this program to run for me. Apparently I just happen to be the only one who is having these issues. Just my luck. Even with the recomended Windows 10 an 8 gigs of ram I still can't get this program to work. I don't know what is more frustrating, not getting the program to work or not knowing why the program won't work.
    Robert Stack wouldn't go near this Unsolved Mystery.
  • Just bought this program today, June 4 2020, and I get the same error report. Running on Win 10 64 bit, 8g ram, Nvidia 1060 vCard, 2.6 g dual core Intel processor.
    Oh nooo... DS has been the reason for not moving into Linux... If it starts requiring Win 10, I guess it means farewell to windows OS:s...
