Environment Settings Save Failure
david_23523141
Hello All,
I have created a simple figure standing with lighting using only the Sky and Sun with the time of day set and the Y axis of the sky dome rotated to where I need it. Saving the Daz scene file did not save the Dome Orientation Y Axis manipulation. I tested this to recreate the save failure and indeed repeatedly the Y axis dome rotation did not save. The scene file would open with the Y axis rotation set to another position. Now, turning ON Draw Dome and saving with the Draw Dome ON and visible seems to have corrected this save issue, so it appears one needs to save the file with Draw Dome turned ON? This was my experience and I'm curious if others can repeat this save failure.
Thanks
Under Edit>Preferences>Scene>Render Settings, be sure to check "Record when saving a Scene file"
Hi Fast, thanks for the tip. I checked my preferences, as far as I can tell this ON and has been left ON.
