Where are my fingernails?
MegaPMegaP Posts: 180
Ok,I'm puzzled.
My fingernails are set to 0 opacity but aren't showing up.
May of removed them fitting gloves but should be back when I adjust back to 100.
Weird....
Hoping someone can fix my nail biter:-(
    What figure is this, and what texture are you using?
  • MegaPMegaP Posts: 180
    Hi Jimmy,
    She is a V4 and texture is Annie from Renderosity
    http://www.renderosity.com/mod/bcs/sv7-annie/99689/
    Fingernails are usually part of the Limbs texture. If you use the Surface Selection Tool (Alt+Shift+M), select the hand, go to the Diffuse channel for that, right-click, use the Browse option to find the texture file on your HDD. Try loading that again.
    If that does not work, go to where you loaded the MATs the first time, hold down the Ctrl key while double clicking on them, and you will be given an option to 'Replace' the current texture.
    See if any of that helps. I don't have this figure myself.
    Thanks Jimmy,
    Second option worked with a bit of fiddling.
    You're great and much appreciated.
    Until next time.....
    Thank you for the kind words.
    Textures can be a pain at times :)
    Your and others help is so invaluable.
    I'm jumping in leaps and bounds but thinking I'm sticking around in this Forum for a while.
    Would like to post some work but here's not the place although I have posted in the gallery section.
    Not to sure If I can add a link
    If you go to 'Your Control Panel' at the top of the forum, then select 'Edit Signature', you can put a link to your Gallery in there, and it will appear in every post that you make. I think that is how most people do it.
  • Richard HaseltineRichard Haseltine Posts: 111,508
    0% Opacity is no opacity - total transparency.
    Sorry bad typo on my side Richard
