Super Hero Suit for Genesis 2 Female(s) and Victoria 6 Neck Lines
Hi, I have made some great renders using Super Hero Suit for Genesis 2 Female(s) and Victoria 6, on a few characters i created. Except I am having an issue with squiggly lines on the neck.i had the same issue in hands when not using gloves but I fixed that by turning off visibility every single instance after hand leve on both hands in scene tab. I cant get rid of the neck lines though. I tried turning off Head and Lower Jaw. If I turn off neck I lose the collar. Anyone else had this issue?
  • felisfelis Posts: 5,962
    Iray has some weirdness.
    Is your character located as world center, i.e. 0,0,0?
    If not, try to move her there and redo render.
  • If nothing is working... a short-term solution is to just render her neck without the suit.
    1: Use the area-select render tool to focus on the neck and render only that chunk. It will render the rest as full ALPHA.
    2: Bring that into any art program as a new layer, over the rendered image with the neck lines.
    3: Erase any part of the naked neck that is covering the suit. (Or you can do it reverse, with the naked neck on the layer below and erase the lines instead.)
