Prehistoric Princess
dragonsfirenhdragonsfirenh Posts: 28
Anyone having issues with this item? It does not seem to conform properly to any of the Gen2 ladies.
  • Richard HaseltineRichard Haseltine Posts: 108,758
    Are you sure it's fitted to the G2F?
  • dragonsfirenhdragonsfirenh Posts: 28
    Yeah, everything else I have works just not this outfit.
    Supported Shapes
    Olympia 6
    Teen Josie 6
    Gia 6
    Girl 6
    Other Genesis 2 Female Shapes supported by Auto-follow
  • BeeMKayBeeMKay Posts: 7,019
    I have the same problem with this outfit.
    Even if you manually dial in Olympia via the parameters tab, it will not fit properly.
    Cool so I am not being a newb :)
  • Digital Lite DesignDigital Lite Design Posts: 728
    If you r-click the dress in the scene and choose "Fit To" does it list Genesis 2 Female? If not, select the figure and see if it works for you then....
  • AlowynAlowyn Posts: 33
    When I load the dress with Olympia selected it loads like you show, but when I target the dress and fit it to Olympia it renders fine for me.
    -D
    1280 x 720 - 177K
    Dangit I am a newb!
    Nah! Your just in a hurry to render a not quite nekkid Vickie in a temple with a sword...)
    -D
    Yes, if you fit it directly, it works, even though the parameter tab already says it is fitted to Olympia before the additional fitting session.
    Thanks for the workaround. :-)
    -D
    You could be on to something ;)
    The workaround allows a nice fit for M6, too. :-)
    1400 x 1400 - 3M
  • Carl FisherCarl Fisher Posts: 135
    You should have an update in DIM now so that the dress loads fit-to correctly.
  • maraichmaraich Posts: 494
    Can someone please pose this so I can tell if the loincloth is parented to the thighs or not? A dynamic pose with the figure running or something so that the legs are just set next to each other.
    edited December 2013
    The right-side sash is rigged to the right thigh; the front and back flaps have their own bones (two in front, one in back). I was pleasantly surprised at how much movement this actually has with the included helper morphs plus the bones. Or I should say, pleasantly impressed; Bobbie25 and Sarsa are pretty consistent with making things that move as they logically should, and doing the work to make them do so. I have a few of their DAZ O's.
    1023 x 843 - 323K
    Post edited by SickleYield on
    Thank you, that is a big help.
  • brainmuffinbrainmuffin Posts: 1,276
    -D
    +1
  • RuphussRuphuss Posts: 2,631
    I would buy this set right away
    but the huge belt buckle somehow looks wrong for me
    Well, it doesn't really scream "prehistoric" that's for sure. However, the giant belt buckle is one of my favorite features. Amazing how tastes can vary so much.
