MC-MMM DAZ Studio, which DS version?
sriesch
in The Commons
Does anybody know what version(s) of DS "MC-MMM DAZ Studio" ( https://www.daz3d.com/mc-mmm-daz-studio ) will work in?
Likely the current one using 3Delight render engine
if you are using iray it is less certain, it depends on if procedural or texture map based
The what's included only mentions textures maps, no shaders at all (although the description does mention shaders, so I am not sure which is true). In any case it should work in any version of Daz Studio, and with any renderer, if you manually set up the shader yourself, and then plug in the relevant texture maps.
