Where to find and control anatomy
Hi, I know a popular question around is how to get genitals for models and the typical answer is Pro bundles so I got a couple of pro bundles (genesis 6 and 8 males) now im having troubles finding the genitals for genesis 8 male and even though I found the genesis 6 ones, i still dont know how to pose or manipulate it (i.e. make it erect). Do I need to buy something else to be able to pose it?
Once G8M is loaded you also need to go to the folder labedl 'Anatomy" in the G8M tree and load it onto character, then when it's attacked you can click it to bring up the base morphs (such as erect ect).
There really isn't an "erect" option. About the best you can get with the male pro pack genitals is a "straight flaccid shaft". They're designed more for depicting general movement rather than sexual functionality.
I stand corrected. There are options such as length, erect, circumcised/uncircumcised, etc., for G3 Male(not sure about G8 or other generations) but you need to select the male gens and if I recall correctly, under either the Parameters tab or Posing tab, you have to select "Actor" and those options will show up. Given that the shaft portion is divided up into 6 individually poseable segments with each having its own basic scalability, and the testes divided into left & right with their own posing/scalability, its not completely useless. Nevertheless, as others have pointed out, for more versatility, there are better & more detailed products for this type of thing.
