Issue with importing hair .obj
I am trying to upload a hair object to c4d and daz3d. When I open the object in 3d viewer it is nice and detailed, (left in the picture) but when I import it it looks bad (right in the picture).
I’ve got the feeling the solution is really simple, what am I missing?
Your attachment has been deleted due to Obscenity in the tille. Please reload it wioth a different name.
The prolem seems to be with transparency, there should be a trans map with that hair
Thanks for your reply. I reuploaded it.
What do you mean by trans map?
To acheive the proper hair look the model needs transmaps to stop it looking solid
Transparency map is a map which tells the render engines which parts of the mesh should be transparent.
