How to move two objects at the same time
I have a figure riding a horse how I move the figure and the horse together at the same time To place them in the scene
Parent one to the other and move the parent.
Or group them. Select everything to do with the rider and horse, that means EVERYTHING
(I've had the odd item left behind and wondered what it was floating in space) then go to Menu Create/new group, name the group and save.
Thank you !!!!
You can also use the Secondary Node option in the Tool Settings pane to move them both via the Viewport widget, with both selected by the figure node.
You could feature-request an option to add fitted items to a new group even where they are not prented to the selected figure (Rob suggested that, though that doesn't guarantee the request would make the cut for implementation).
Works well. Thanks.
Thanks, ALL!
