texture issue
R1CH1R1CH1 Posts: 80
edited December 2013 in The Commons
hey, I have been using Daz for a while. I just started using the Gen2 /Victoria 6. Does anyone else notice any issues with the textures when they load? I'm sure I can tweak around in Surfacing, but I never had to in the past on the older models. Here's a grab. Victoria 6 with Belle skin at 50 SS, with a Gen 2, Nyssa face.
Post edited by R1CH1 on
    Are the face and the skin from different texture sets? Because no, that's not going to work in general.
  • R1CH1R1CH1 Posts: 80
    yes, the overall skin is the Belle skin that comes with the V6, and the face is Silver/ Nyssa, which also came with V6, but not from the same set. so if I want a particular face make up or something, I have to use the entire set? I don't even think that face has a full body skin.. it's just a make-up face. So if I want a figure's face made up a certain way I should just photoshop a file copy in the same set?
    Yep. ForbiddenWhispers sells some just-makeup psd files to help with that as well, IIRC.
  • JessaiiJessaii Posts: 845
    Nyssa has a Mat Def which applies the full default mat. . . You then can load any of the makeup or lip options on top of that.
