İray server connection error on Google cloud vm
I want to use iray server on google cloud vm.I installed iray server on vm.I tried to add a job from my local daz computer but it gave me an error bridge error the connection failed please check the server adress.Then I installed daz studio in my vm.Even then when I try to add job from daz studio in my vm to iray server which I created in my vm it gave me the same error.I tried on a different computer I can add jobs from daz to iray server which I created in that computer.So why cant I do the same thing in my google cloud vm
I want to use google compute for on my project in daz3d.Since google zync doesnt support daz I tried to import my files to maya then render it google vm.İt worked but some materials went missing and its very hard to import all the scenes just for rendering.Then I saw a guy is conneting his google vm to iray server and use their gpu power to render his projects.I want to try the same thing but but ı dont know how.I already installed iray server.And create a google vm instance with rdp connection.But I am having a hard time to connect this vm to iray server.Any help about that?
You're going to need to install iray server in the VM. Once that's done you should be able to connect directly from your local Daz program by inputing the correct ip address and your user and Pw in the advanced render settings bridge tab.
I am having problems with installing iray server on vm.Can I just dowload it from internet explorer using rdp connection or do I have to use command line
Threads merged
It's linux, I assume, you might be able to remote into it and run a GUI like Mint but that depends on a lot of factors. Installing from the command line is the best, and likely simplest way. iRay server should have installation instructions. Follow them.
probably a firewall issue.
