My phone will not charge complaint thread
Adding to Cart…
this is 1 reason i keep all the promos in a folder on my desktop,
visually scan large thumbnails
however, this fails when the promo doesn't have the name of the product on it
then i have to right click properties to get the thumbnail name,
is hypernate like a power nap?
nomms the nitrates
is it true what they say about green MnMs?
From reading other threads it seems like a lot of people are building new or majorly upgrading their system. And it seems to be a lot of very old systems
. Must be that 2010ish was an era of well built adequate machines that just kept on running and running and running like the "Energizer Bunny".
Non-complaint: I got into upgrade mode when I essentially gutted a decade(ish) old desktop to build a nice modern machine with new motherboard, current class CPU, faster/more RAM, bigger powersuppy.
Seeing how well that worked, I then I replaced the hard drive in my decade(ish) old laptop with an SSD. Again success
. And now today I'm finishing moderately upgrading another decade(ish) old desktop by replacing the hard drive with an SSD. All three of those computers have (or had) been upgraded to bigger hard drives, max RAM, and Win10 a long time ago but the advance to SSD still makes a major improvement on how well they run Win10. Very happy
. It's a good time to know how to do this type of tinkering. I've been having a ball, digging in to my old parts boxes for screws, better/bigger secondary hard drives for internal storage or backup, shorter cables, and tie-wraps for organizing the wiring, It keeps these old hands and brain busy and away from the TV.
Complaint: I'm running out of money and old desktops to upgrade.
My late-2013 iMac (the last model with an NVidia card) has a failing internal hybrid drive. Basically nothing works, or takes ten minutes or more to work. Awaiting an external drive that can be recruited as a new boot drive because iMac is basically impossible to self repair (you have to remove the front glass which is attached by adhesive to open it at all). Amazon sells a replacment kit with tools for $350. Yipe.
complaint miss kulay still absentia
I have that thing! It plays "Kung Fu Fighting" while it twirls the nunchaku.
Dana
I decided on my Halloween costume... I'm going as zombie #256 from the first season of "The Walking Dead"... but as he appeared two weeks before the Zombie Apocalypse occurred.
Nobody will figure that out.
That they are colored green by a rare type of algae that on the surfaces of septic pools?... yes.
Hypernate is absolutely like a power nap.
complaint: I've completely abandoned trying to render on any of my other computers... mostly. I still need to test my laptop. Compared to my normal system the others take 2 to 4 times longer on the same scene and if the scene is memory intensive then forget about it.
I may end up using them for storage since I'm running out of space fast.
I really need to retire a couple of older computers. But that would require organizing everything and moving my email accounts and reinstalling programs that I may have lost the discs to. So much effort.
...as long as they don't drive around in Kias. Traffic is bad enough the way it is here.
...indeed, that place she's in sounds more like a prison than a group home.
this place has gone to the hamsters...
could be worse... it could be overrun with flamingos.
snooty birds...
But synchronized walkers and occasionally a great yo-yoer: https://www.youtube.com/watch?v=OvPjtolajZk
Non-complaint: Wheee... my 2nd desktop has been upgraded to using a 500GB SSD and WOW is it frisky now!
However, I do have to admit that during the process of cloning the hard drive using the "Acronis" app provided by Crucial, a bad sector was found that caused the clone operation to pause and give me some options to resolve it. Per their suggestion I tried to use native Microsoft tools to identify and repair the error but they couldn't find anything wrong. So, I finally just took the option to "Skip it" and it only found the one bad sector so I hope that it was in an unused spot on the drive. Also during the cloning operation and other normal operations of the system I had been observing the Windows "swap area" statistics and began to believe that the 4GB RAM memory (all this machine can handle) was running at least 3/4 full all the time and was doing more "swapping" than is efficient. And there was only one drive in the system so when it was "swapping" it was having to swing the drive's access arm between data areas and swap area. This, and the bad disk sector may have been contributing to the terribly slow performance it had been giving for the last couple of years. So, after the clone was complete and I was satisfied that the system was running again (very spritely, in fact
) I reached into my box of used hard drives, found one that was 750GB and I modified Win10 to write its swap files to the hard drive instead of the SSD to avoid excessive writes & rewrites to the SSD. Yeah, it will be a little slower, but I shouldn't let it do a lot of swapping anyway. So I still have a little work to trim down the RAM usage & discard unecessary resident apps. Having the larger secondary hard drive in the system also gives me an internal backup disk.
This is now a very nice, fast, little machine for everyday stuff. Not a graphic wizard but it is very quick.
(Note: the original hard drive has been removed, and stored in an anti-static bag labeled as to what data it contains, and as "Possibly Bad" and tossed into my box of archive data.)
('Nother note: Who would have thought that 4GB isn't quite enough memory for running an operating system?
My first machine in college had 16K bytes!)
...uh oh,, wInter weather advisory for Milwaukee WI with 2" - 5" of snow forecast for tonight and tomorrow and then temps down into the mid 20s. Looks like the trick or treaters will have to bundle up and put their galoshes on tomorrow night.
Glad I don't live there anymore.
I saw a new dentist in the dentist office today. He did not introduce himself. I guess he was in a hurry to eat lunch? I can understand why some people think some doctors are rude.
plainnt between weather and traffic, bus ride home was 3 hours, from bohemia to huntington
reeedickyooluss
have an idea for a new tradition
winner of the thread title makes a banner for it !! a nice sig sized banner
i miss going to halloween parties
i miss going to parties
i miss going out
do people still line dance?
would they let me in a dance club with my walker?
shall we dance dun duh duhn - the japanese version lol
kings are fast learners
that laugh omg
.. I love that that scene.
...my favourite laugh:
This along with her "beeg bada boom" was the basis for my character Leela.
i had some weirdly dreams this morning.
Halloween ready: Pumpkin carved. Candy set out in dishes. I never (well hardly ever), get any trick-or-treaters so it's all for me! Yay!
Of course I've bought my type of candy.
I did, however, just a few days ago get a surprise visit from a Seventh-Day-Adventist delegation wanting to talk to me about the good word in the Bible. They went away without a conversation and of course didn't get any candy.
trick or treat!! tnite is the nite to watch achmed the undead terrorist
ahwooo lycans
oh boyy sale today got me good. Retail High!
spent my 8tb drive monies dooooh
Did it involve the octopus with a top hat, riding a skateboard handing out free large Frostys from Wendy's?
I like that one because I feel hopeful when I wake up... mostly hopeful that I'll find a free frosty on the dining table when I go downstairs... then I'm usually sad because the Frosty Octopus hasn't visited.. I know he's real.. he must be... why is life so cruel and devoid of dessert bearing cephalopods?
Now I have to go to the terrible local Wendy's and order my own Frosty from the terrible people who work there... If I order even one thing, they'll find a way to get it wrong.. they are so bad at everything.
I hope your weirdly dream was betterly.
What happens if you let them in? Has anyone ever done so, and can tell the tale? I've never met any SDAs, that I'm aware of, but my Mom once let some Jehova's Witnesses in and gave them coffee. Then they became friends, although Mom never converted.
With this being a spoopy night and all, make sure that no one who knocks on your door has all-black eyes (like an alien). If they do, you need to slam the door in their faces, and shut yourself in a room that doesn't have windows until they stop knocking and begging to be let in.
Candy is bad for you... it contains sugar and that can make your heart fall out and make your teeth fat... you should give it to me, I've had my shots so it won't effect me like that.
You didn't have any conversation with them? My conversation usually is... "Stop ringing the damn bell, I told you I worship Cthulhu, he that slumbers in R'lyeh and will rise again to rule the earth"... alternatively I also substitute Satan or The Flying Spaghetti Monster... They usually come to the front door, where I politely tell them I'm insane and then they go to either of the side doors and knock or ring the doorbells... maybe they are hoping I'll have changed my outlook on religion by the time I get to those doors... alas, I am only annoyed by that point.
I'm very disappointed that I still haven't printed up my own pamphlets for my own wacky religion to hand to them... I've been meaning to do that for years.
