Deleting Orphaned References/Icons from Smart Content Pane in 4.11 or 4.12
SBibb
I have several user-created files that I'm trying to delete, but once I delete or move them outside of Daz, it leaves a little exclamation point icon in the smart content manager.
I can't seem to find a way to delete those icons, and most of the suggestions I found referenced older versions of Daz that no longer have the same options.
I'm currently using Daz 4.11 and 4.12 Beta.
Any suggestions?
They should be findable in the Content Library pane, under Categories, and you should then be able to trmove them via the right-click menu.
Ah, thank you! I had to give them a category first, but once I did that they showed up and it let me delete them.
Thanks again! That'll make it much easier to sort through now. :-)
Thank you so much.
