Renderings Deformed.
Can anyone tell me why this is happening when Posing G8F figure.
P.S. Big girl Morphs are not installed.
Not sure why you need a new thread when you have clearly found older ones. To identify the product causing this you need to trigger the effect, then look at the parameters pane -turn on Show Hidden Properties in the option menu, if it isn't (the line button in the top corner, or right-click the tab) and then look through the Currently Used group to figure out which morph is in effect when it shouldn't be.
