How to get Chill boots to fit G8F???
The new outfit Ravenhair Chill for Genesis 8 Female(s). Need help getting this outfit (the boots) to fit standard G8F (grrrrr). Her feet stick out the bottom of the boots regardless of what I do to prevent it. An I first apply the flat feet pose included but that doesn't prevent it either. Help please.
Do you have the Geometry Editor tool active, or the Node Weight Paintbrush tool?
Never mind I kept at it and found a solution. Load the boots without having G8F selected then after the boots are loaded then parent them to G8F and have them autofit to G8F seems to do the trick.
For the record, I don't know what the OP's problem was, but the boots load fine for me by selecting the character and then applying either the boots or the outfit including the boots without any special efforts being necessary whether the character is in zero pose or not and the correct foot pose is applied along with the boots.
