Carrara Challenge #49 - THE FORBIDDEN ZONE WIP (sponsored by DAZ :) Entries closed
123457
  • StezzaStezza Posts: 8,819
    I also have had problems with the Carrara products that I do load in the C drive showing up in the browser.  It's kind of a mystery to me how to add stuff.  Using DIM, some of Dart's products went right in, but other vendor products went to obscure locations, and were hard to find.
    Instal all your Carrara products in the Carrara folder
    then most times you will have to add them manually by browsing to the file location using the add folder tab.
    also, you can find not only scene files but also lots of other goodies under objects, shaders, lights, trees and all.. but you need to add them under the corresponding tab browser ..
    ie.. scenes - objects - shaders - misc
    there is a heap of stuff you will find adding manually... which unfortunately Carrara doesn't do automagically for you.  yes
    bit more info....
    Yosemete ( did I spell that right? ) HDR files are found in
    Cararra/Presets/Textures/DimensionTheory/HDR Pro-Sets/Yosemite
    yes
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,288
    edited October 2019
    Dunno as I have every HDR file on my computer copied to a panorama folder on an external for every application, I simply searched *.HDR and copied them all and the Yosemite ones are in there with all the others including ones from Hitfilm, Reality, Octane  and other apps.
    I just browse there when I want a HDR
    I also have a program I installed from Sourceforge that shows them and nearly every other image format as thumbnails, was a lucky bonus as exr files were what were annoying me and I wanted to see but it did the HDR ones too.
  • UnifiedBrainUnifiedBrain Posts: 3,588
    I appreciate you guys trying to help.  Unfortunately...
    I cannot load the Yosemite product file into Carrara because I don't have the room on my C drive.  So to get around that, I put the files elsewhere, and attempted to load them via scene>background>HDRI.  It doesn't work, because none of the Yosemite files have .hdr or .hdri in the suffix.  Instead, they have .cbr (Carrara version) or .tiff (Daz version).  Changing the suffix doesn't work either.
    I have to assume that you guys are NOT using the scene>background>hdri pathway.  It usually works perfectly for me, but not on this product.
    This must be some kind of special HDRI.  If I add the file into the browser, nothing shows up in it.  It is blank.
    I will probably have to wait for a better machine to use this product, and that is on me.  Thanks for trying.yes
    edited October 2019
    Odd I definitely have Yosemite files with HDR too, did you look in runtime textures DimensionTheory?
    C:\Users\Public\Documents\My DAZ 3D Library\Runtime\textures\DimensionTheory\HDRProSets\Yosemite has hdr files
    https://sourceforge.net/projects/sagethumbs/
    it doesn't like the tif think 2ff OK though and the big hdr ones too much for it
    1919 x 1078 - 437K
    edited October 2019
    You've done it again, Wendy.  I realized that I hadn't followed EVERY fille down to the bottom.  Yes, there were hdr files, and they work!  Not easy to navigate when they are in Carrara, but that's just a quibble.
    Many thanks. yes
    Not so forbidden
    1347 x 898 - 195K
    Post edited by UnifiedBrain on
    I always instal Carrara files manually ... so they don't end up all over the place via the DiM instead of where they should be.
    good you finally found them yes
  • VarselVarsel Posts: 574
    edited October 2019
    Here's another from me.
    A red light normally means stop-do not enter- stay back....... but it can also mean... wink
    Using Stonemason The Streets Of Old London
    1920 x 1080 - 647K
    1920 x 1080 - 970K
    Post edited by Varsel on
    Definitely a forbidden zone, well done Varsel.  Even if I was tempted, I'd think twice before entering that gloomy alley. :)
    wip ch49  suddenly, heard a knocking on the door
    the trick to using ravenskull barlow house in carrara is to delete the .mtl files in the geometry folder.
    there was a trick to bringing the dress into the scene, dragging it in, the conform made the dress pop like a foot in front of Steph.
    i tried the load clothes button, doing it that way the dress loaded where it should be.
    other trick i tried, put a cube around the set to contain the raytrace bounces and idl calcs. (to infinity and beyond)
    to put more light on the phoenix feathers i added a dedicated bulb to the bird, light only bird, no shadows.
    Ain't no respite here
    516 x 494 - 61K
    1800 x 759 - 2M
    971 x 587 - 113K
    957 x 540 - 89K
    1800 x 759 - 2M
    1800 x 759 - 2M
    wip  Quiet time with a Demonix
    had a go at using the wrench in the assembly room.
    fixing bow knots poke.
    used Stephanie P3, Irina char.
    https://www.daz3d.com/night-of-the-living-daz-belthazor  lol
    used some carrara native content shaders, 3 pt light set
    Quiet time with a Demonix cutie  (but which figure is the demonix)
    cant just right click thong in preview, must navigate instances to model.JPG
    795 x 540 - 74K
    971 x 537 - 116K
    1280 x 1774 - 1M
    1280 x 1774 - 1M
    1280 x 1118 - 1M
    1280 x 1118 - 1M
    Love the camera angle, Misty.  Very unusual.yes  Great title as well. :)
    Also great to see a prop and artist completely unfamiliar to me.  Awesome textures.
    Is she an ethereal entity, and floating?  She appears to have no feet. :)
    Wonderful to see Steph Petite 3!  The Irina morph is terrific.  I assume that it is no longer in the store?
    The render just pops off the page.  Reminds me of some pulp art.for the 70's.  Nicely done.
    I updated the Art Studio forum post.  Did it before Misty added her latest, so I need to add them to the next batch.
    thanks.
    tried many angles and framing
    ravenskull is haunted, she a ghost   was happy to find the floor train style dress  had a couple of faux starts with it,   dunno why sometimes the outfit hovers in front of the figure on conforming
  • DiomedeDiomede Posts: 15,398
    edited October 2019
    UB, glad you got the HDR working for you.  It is a very useful supplement.
    Fantastic job, Varsel and Misty.  These late entries are wonderful.
    Swap Update.
    I did a little touch up to the Sherwood Forest image.
    1600 x 1200 - 490K
    Post edited by Diomede on
  • namtar3dnamtar3d Posts: 254
    edited October 2019
    Here's another entry, very simple but i feel a "forbidden" challenge needs a darker entry :P
    Also, i love all entries and ideas, i'm just too bad speaking english (and too noob) to make a good comment about them.
    By the way, i want to share this third alternative version of my first entry:
    1664 x 1007 - 339K
    1616 x 950 - 517K
    4096 x 2304 - 1M
    Post edited by namtar3d on
    Diomede said:
    Bwahahahaha!
    The mad scientist replaces human brains.
    Carrara Toon! Part III native filter.
    Everything modeled, rigged, and posed in Carrara.
    Well i can't say nothing but it is awesome, it takes me hours just to pose base figures.  Modeling, riging and posing would take me years. Well done!
    edited October 2019
    Thanks for the kind words, Namtar3d.
    Peeping George is going to get severe punishment if he is caught.  All of the versions of your sphere entry are great. What I like about the most recent is seeing the details of the tattoos on the heroine, but then lose some of the detail of the creature. Always hard to choose, but the effects of each are spectacular.
  • the last stop
    this render without the splat in front of the camera.
    the splat is 100% transparency, don't cast or receive shadows, 0 highlight, ior 1.02 and HAVE bump!
    to renser it you need raytraced dof.
    so i'll render it over night.
  • the last stop
    1280 x 960 - 2M
  • ed3Ded3D Posts: 2,513
    edited October 2019
    _Entry thread closes/ voting begins Wednesday October 23, 2019_
    _And is it  Morning or Night  ??
    - thanx _
    Post edited by ed3D on
    edited October 2019
    Stezza said:
    bit more info....
    yes
    OS X Yosemite _
    - thanx _
  • HeadwaxHeadwax Posts: 10,435
    wow what a bunch of stand out renders - sorry been away organising a painting show
    really looking forward to examining all the work
    thanks for the headsup UB - get something in that thread tomorrow!
    edited October 2019
    One last entry for me, I AM FIRE!! I AM DEATH!!
    Just playing with Carrara physics a bit :P
    1673 x 880 - 587K
    1920 x 1440 - 2M
    1920 x 1440 - 2M
  • Bunyip02Bunyip02 Posts: 9,275
    Wow - lots of work added since last comment by me !!!
    Varsel - love the tinnie in his hand in the tunnel work
    namtar3d - vary nice series of work, very glad you joined in
    Diomede - had a good chuckle over the selection of brain sizes
    UB - hope you get to use those HDRs, they are excellent to work with
    Misty - great use of camera angle on Ain't no respite
    shlomi laszlo - looks like a lot of hangmen in that place
    ed3D - joining in ?
    Headwax - hope the painting show is going great
    edited October 2019
    Namtar, you ARE on fire!  Great 2nd and 3rd entries.  On the dragon, I like the hot version the best.
    Shlomi, looking forward to seeing the finished version!
    ed3d, I will open the voting on Wednesday whenever I get around to it. :)  Tomorrow (Tues) is the last FULL day to enter.
    HW, hope you can enter some more renders, but for sure enter the Freak render.yes
    Really missing seeing work from Vyusur and evilproducer.  sad
    Edit - just before falling asleep last night, I realized that it sounded like those were the only artists I missed seeing.  Not even close.  Others include PhilW, desertdude, Jonstark, Dustrider - the list could get really huge, so I will stop now while I am behind. :)
    edited October 2019
    I made this gold coins tileable material for my third entry, is far to be perfect, but maybe could be useful for someone. So, here it is:
    NOTE: Use gold texture as specular, set mesh color as black or almost black.
    SAMPLE IN OCTANE
    SAMPLE IN CARRARA NATIVE RENDERER
    For the Carrara native engine you can use the "Electrum" preset material, then load this textures to get a cool effect.
    1120 x 840 - 1M
    1120 x 840 - 170K
    1120 x 840 - 329K
    1920 x 1440 - 2M
    1920 x 1440 - 3M
    274 x 705 - 145K
    256 x 347 - 66K
    1920 x 1440 - 2M
    Great texture Namtar, thanks for sharing!
    When I said earlier that I like the hot version of the dragon, I meant this one:
    I tend to like reddish tones. :)
    Namtar3D - The dragon images are vibrant and exciting.  Well done.  Thank you so much for the gold coin shader.  I made a leprechaun morph, and I think the little troublemaker needs a pot of gold coins!
    Bunyip - thanks for the nice comment on the brain render.  .
    Hope we see a few more entries before the close, but I think we have another wonderfull field already.  Inspirational theme, UB.  yesyes
