Fitting Mech Dancer and other things to a Genesis 8 figure
agate888
Hiya. So I am a infrequent user of 3D and Daz, so it's very possible the answer is obvious, but I run into this now and then. Certain outfits don't fit a Genesis 8 figure right...there is poke through or it just doens't cover the skin (it's under it). The lates problem is the amazing Mech Dancer outfit/armor/costume. Here is a view that shows what I am talking about, where the black body suit doesn't cover her right OR the armor part doesnt work right in cover her bodsuited body. What's the solution? My figure is like a mix of shapes to Genesis 8, but mostly Victoria and I think it's Maebrie (sp).
https://www.dropbox.com/s/pgnpatdnfv9mc4e/backviewCyberAngel101619.png?dl=0
https://www.dropbox.com/s/adwq1t717ri0g26/KahliMech101119a.png?dl=0
Are there any clothing morph adjustments in the outfit?
There are a lot of possible adjustments listed on the product page, but I am not sure if they are morphs or just clothing poses that require dForce simulation?
(I have not even attempted to figure out use of dForce at all yet - still working on the basic stuff first.)
https://www.daz3d.com/dforce-mech-dancer-outfit-for-genesis-8-females
I mean I thought that idea was you applied Genesis 8 clothes to a Genesis 8 figure, and boom, it was suppose to work regardless of morphs or body adjustments. This one isn't working great...the back of the thighs and nips and under boob not covered right by whatever part of the outfit. There are adjustments to the outfit, but they don't seem to solve anything, just distort the outfit wrong.
I am using a shape that isn't supported it seems. Like if I switched the body shape strictly to somthing supported, like Victoria, would it work? But disappointed I won't be able to use a shape I like mixed with others that I customized, if so.
Unfortunately, that is the nature of the beast. A PA can only support so many shapes because it's a time-consuming problem. However, some products can help with the issue. Before I get into that, though, have you checked what the outfit is colliding within the parameters tab? Most things load with collision set to the figure, but if you're adding something underneath, then you'll need to change the collision to that object.
If that still doesn't work, you can also try one of the following products, which will add further morphs to the clothing allowing you to adjust the problem areas:
