Trouble with HeadShop OneClick Install
Wanderer
Hi,
So, after not having Daz installed for a while due to this and that, I finally got my new system built and stable, and presto--back in the saddle with clean install of all content. Except, so far, for one item. HeadShop OneClick. DIM did most things fine up to that point--need to make sure everything else works to be sure. But on this it says, "Could not find local ReadMe for : HeadShop OneClick (WIN)" and "Download Failed!" Uhm... okay.
I'm running Daz on primary SSD with my user folders (not all of them) and public user folders moved to secondary HDD. I have the link/junction thingy set so that Windows 10 knows where to send my public user files (I did a move for my personal user files). I tried looking at other posts to see if this was already resolved, but I don't see this particular error anywhere. I apologize if I simply missed it somewhere.
I have a bunch of content waiting to install until I get all of the paths set up (Bryce, Carrara, etc.), but this is the only download failure.
Any suggestions?
HeadShop does not use DIM, you have to unzip and install using its own installer. Here's an install video (shows HeadShop 11 but also applies to OneClick).
Okay, thank you! Sorry I missed it since I was searching by that particular error.
