Question about e-mail links
noquiexisnoquiexis Posts: 32
edited December 1969 in Art Studio
I am frequently intrigued by the pictures at the bottom of the e-mails from DAZ (PC Render Contest), but clicking on the picture, the " PC Inspirations Contest Thread", or the "Monthly Render Challenge" links only lead to the forum home page. How does one find the actual picture so that it may be seen in a larger format? I was specifically looking for "John Carter of Mars" by aemccullough. Great picture!
  • Richard HaseltineRichard Haseltine Posts: 108,758
    Try logging in, assuming you aren't when you go to the site initially, and then click the links again - the images are in threads in the Members Only forum, to which you should have access.
    You are a member of the Platinum Club, so the link should take you to the image. You will need to make sure that you are logged in, as non-PC members cannot see the Members forum, and if you are not logged in, you are treated as a non-PC member.
    I just tried this myself, and it takes me to the Forums home page as well, something wrong with the links I think. Anything like this, you would be better to post in the Members forum, moderators can then see it, and hopefully get it fixed.
    OK, that doesn't work - I'll report this as an issue. In the meantime, the John Carter image should be in this thread http://www.daz3d.com/forums/discussion/31604/
  • noquiexisnoquiexis Posts: 32
    Richard Haseltine wrote
    Try logging in, assuming you aren’t when you go to the site initially, and then click the links again
    I am always logged into the forum. I logged into the home website as well, but still no joy. I did find aemccullough's "John Carter of Mars" on page 13 of the thread you linked. I did see some excellent renders along the way, but I never would have found this image if I did not even know what thread it was on.
    This is not the first time I have been frustrated by images in DAZ e-mails. Seems to me that if DAZ wants to use members' images in their advertisements, the least they can do is link to that image.
    As I said above, I have reported this so with luck it will be addressed in future newsletters.
