aniMate
taraque2013
Hi again. I just found out that I already have aniMate 2. It came with Daz 4.6 but you have to register it. Well I did that, but it still says disabled. I went to help; about installed plug-ins; clicked on aniMate; copied the serial number; It said to restart Daz and I did, but when I go back to it, it's gray and still says disabled. Knowing that I would have a lot of other problems that I needed help with, I kinda didn't want to have to ask how to do this seemly simple thing, but it took hours just to learn that I already had it but it wasn't registered. So I am forced to use another lifeline now. So can someone help me out?
So I looked on the log and it says Could not activate animate 2 evaluation. Plug-in disabled. Error writing author data! What does it mean and how do I fix it? Please help.
I believe they give you that program for a 30 day evaluation only after that you have to buy the program....How long have you had Studio up and going??? Trish
I've only been doing this for 4 days. And I can't figure out what is wrong. Can you help?
Did you try to type the serial number in manually??? sometimes that helps...you said you clicked on animate and got the serial number??? That info should be listed in your account....
Yes! I even used CAPS and small caps. I'm thinking of just uninstalling and reinstalling. I've been bogged down with this since noon yesterday.
When you go to the aniMate 2 in Daz products they tell you how to unlock the free software that was already installed onto your computer. There was no registration button to press. And it was already checked. I just had to put in the serial # and restart Daz.
mine looks like this and when I click on it ...it takes me to the page to buy the product.....Trish
yeah, I got the # from my account and then went to the help; to aboout installed plugins and then typed the #
If yours looks like mine and says animate2 this is the product......I think that's just the plug-in to use it once you buy it
yes, so does mine, EXCEPT!!! MY GREEN THINGY IS NOT GREEN IT'S GRAY. At first after I put in the # it turns like yellow. That's to signify to restart Daz. But when I do, it goes back to Gray and at the bottom it says that aniMate is disabled
Once you click it and go to the "about this item" part, it'll say that your Daz 4 comes with it. And then it will tell you how to get it going
I am sorry I am trying to help you but mine will not work till I buy this animate2 is not free....I will click on mine
Once you click on that picture and go to the bottom, it'll tell you that Daz 4 comes with it. And I think you can update your Daz for free
ok heres what I get and what it says at the bottom of my page
Animate 2 is FREE to TRY for 30 days, to get the ANIMATE2 Serial number you must BUY AniMate2. The DAZ Studio serial number does NOT unlock the AniMate 2 plugin.
Okay so do you think that at the bottom of the aniMate product info, they are telling me that it is already installed but I can't use it til I buy it and then put in the new registration code? I'm starting to think that is what the stuff at the bottom meant. And how did you get a free trial of it?
Thank you for clearing that up. Now how do I get the free trial and is there an aniMate 1 still out there?
You killed the Trial by putting IN a serial number that is invalid. I know of NO way to fix that. AniMate2 trial IS built into DAZ Studio now. You could have just used it for 30 days. Then it would have turned into AniMate Lite until you bought AniMate2 and put in a FULL serial number.
Okay... So what I reinstall Daz pro and maybe that will reboot my animate 2? So shouldn't I still have aniMate lite?
I very much doubt it. The invalid serial number is now Perm on your PC only buying AniMate2 will fix you I think. But you can try.
Thanks alot I don't mind so much of messing it up, that's part of being a newb. I can now go to sleep and figure out what else I don't know before I mess that up too. I never saw the animate tab. was it in windows\panes and now that I don't have it it disappeared? Cause there isn't even a non-colored area for the animate tab to be selected. Well anyway I still have to put in 3 hours of Skyrim before I can go to sleep. They sent me all the way across the continent while I was sleep yesterday, so I gotta get back. Thanks again. Good night!
Yes AniMate is in the Windows Pane(Tabs) I keep mine docked to the Bottom of my viewport.
Here it is closed and opened...
Who's 'they'?
Might be a good idea to run a scan, even via the Microsoft updates - removal tool. [if your using a Windows computer].
If you installed via DIM, you can uninstall via DIM. If you installed manually, turn off the CMS, you can uninstall CMS, and D/S ... and then reboot the computer and then reinstall the program which will then reinstall the CMS.
And again, if on Windows, right click on the installer and run as Admin.
AniMate2 also comes in a bundle with aniblocks and is a better deal if you wish to wait for them to go on sale sometime next year.
About the 'no room for it' ... to get it as a tab, go up to the top of the program, "Windows > Panes/tabs > AniMate [click on that] ... then dock it on the bottom. Or put it near the bottom stretched out. Next time you open D/S, hopefully it'll be docked there. [the docking bit is quirky on my laptop].
Thanks, I'm just gonna buy the actual aniMate2 since I will need it anyway after the 30 days. When I go to Windows>Panes/tabs, there is never a thing that says aniMate.
After you ran the purchased installer there should be.
You might need to set your Layout to one of the Advanced layouts to get ALL items on the Menu's. Try City Limits from the Windows> Layouts> section.
Ok I seem to be suffering the same problem, only installed Daz3D couple of days ago, definitely had an animate options tab next to the Timeline tab, and even successfully used it to crate some walking animations, this was last night.
Cannot say this 100% but am pretty sure it said Animate Lite and not Animate 2 on that tab.
For certain I have never tried to input any serial number for it into Plugins window, only discovered that plugin window just now after reading this post, and the Animate thing has been missing since I tried Daz3D again today.
When I open the Plugin window it has the Status Icon for Animate 2 greyed out and in the info pane at the bottom says 'Evaluation Disabled', this has to be some kind of bug?
Not very impressed f your telling me that's it and there's nothing you can do, do you think after 30 days it will revert to this Animate Lite function anyway, or will my copy of Daz3D now never have that?
Have attacked a picture showing my Plugin window with the Animate 2 plugin selected.
As it used to revert to animate lite, that's why we were thinking it still should be doing that. As this appears to be happening to more people now, yes it might be a good idea to query CS about the matter. As I have the $plugin, I have the AniMate2 showing.
If it's not showing any manner of getting Animate lite working, then no it won't happen on its own in 30 days.
edit to add: they may have discontinued the trial? Checking the free stuff, the free trial for animate2 is no longer there either.
I think the Free trial was only for a certain time after AniMate2 was released. It might be over now. Only DAZ 3D can answer that for sure or not.
Last night I completely uninstalled Daz3D, including the Content manager and Install manager, and then did a search for Daz3D and manually deleted any remaining folders.
This morning I reinstalled and now I have AniMate Lite tab available again next to the TimeLine tab when in Pose/Animate mode.
Under the 'About Installed Addons' for Animate 2 it now shows as Evaluation Days Remaining 0
So at least I have AniMate Lite back for now, will be interesting to see if it vanishes again later, but its a bit sucky that I haven't had any trial of Animate 2.
Have raised a ticket about it anyway and will see what they say.
