The Riad in the store today
Kendall SearsKendall Sears Posts: 2,995
Does anyone know if this is a rigged model (working doors and such) or a prop building? Cornucopia has a habit of releasing non-rigged items into the DAZ store and I rather not burden customer support with an unnecessary return.
Thanks
Kendall
    Don't have it but in the What's Included & Features section it list only obj format and Poser pp2 prop format so most likely not rigged.
  • FirstBastionFirstBastion Posts: 8,050
    Based on the other Cornucopia props released, they were just static props.
  • Kendall SearsKendall Sears Posts: 2,995
    Thanks, that is what I was thinking as well. 'Tis a shame because it is almost perfect for an upcoming project I have, but I don't really want to spend the time modifying the model if I don't have to. I have too many other responsibilities to spend on that.
    Kendall
  • Teresa TylloTeresa Tyllo Posts: 141
    edited December 2013
    Here is some info+pics. It' static, no moving parts.
    Edited: My image info is from the older product "Riad and Old Street". http://www.daz3d.com/riad-and-old-street
    Sorry for confusion!
    1094 x 933 - 125K
    Post edited by Teresa Tyllo on
    Greetings,
    Sadly, my experience has been that their stuff is typically a single unrigged OBJ, with a single material zone, or material zones which intermix a lot of different pieces at once. You can't even hide doors to make them seem open, or do any tweaking to the image, or use shaders, etc., on the items, you have to go and photoshop the textures, etc., to do anything like that, and sometimes that doesn't work because the textures are re-used and all put in one material zone, so you'd have to re-zone everything.
    It's just a lot of work to make those products flexible, and work that I don't have the time nor inclination to do.
    -- Morgan
  • SorelSorel Posts: 1,412
    I guess they're fine if you just need them to be filler for backgrounds. I recently had to return a bunch of elven buildings at rendo because it turns out they were just bog props with nor dials and one tiny texture map.
  • Joe.CotterJoe.Cotter Posts: 3,362
    You were actually able to return to Rendo? I got a "this one time" message from them the one time I put in for a return and I had a very good reason for the return.
