X-Fashion Tactical Outfit ... "File not found"
JeffG
in The Commons
X-Fashion Tactical Outfit for Genesis 8 Female
https://www.daz3d.com/x-fashion-tactical-outfit-for-genesis-8-females
Trying to download and getting...
"File not found An error occurred during a connection to cloudload.daz3d.com.
Check the file name for capitalization or other typing errors.
Check to see if the file was moved, renamed or deleted."
Is this with DIM or using Connect inside DS?
Both.
I can't download it with DIM or from my library. Same file not found error if I try to download the templates.
Same here, download failed with DIM and file not found in library (cloudload.daz3d.com error).
This site can’t be reached
The webpage at https://cloudload.daz3d.com/zipFiles/64275/IM00064275-01_XFashionTacticalOutfitforGenesis8Females.jar?... might be temporarily down
or it may have moved permanently to a new web address.
ERR_INVALID_RESPONSE
Greetings guys... Same for me... on all counts...
Well Leda HD is fixed so maybe the other products that had the same issue over the weekend might also work now?
It's fixed for me ... actually downloading X-Fashion Tactical Outfit with DIM (download via Product Library works too).
