Hair Thru The Hat
AVU4UAVU4U Posts: 67
As this render shows M4 hair is sticking through his hat. How do I keep this from happening? I'm working on a Mac Pro 8 core in OSX 10.6.8 with Daz4 4.0.3.47. Any help?
  • scorpioscorpio Posts: 8,533
    I usually use Dforms, and a bit of post work to cover any little bits that are left.
  • Richard HaseltineRichard Haseltine Posts: 108,425
    You can also render just the hat, then layer that over the full render and erase it as needed to only mask out the unwanted hair. Lyrra has a set of magnets to help with fitting hair under hats.
  • SzarkSzark Posts: 10,634
    Add to above it also depends on what the material zones are like as I have had some sucess in taking out the trans maps for certian zones and use 0% Opacity making certain parts of the hair invisible
    edited July 2012
    Richard mentioned Lyrra's magnet / deformer set. It can be found here http://www.daz3d.com/shop/deformers-plus-hat-head/
    Post edited by Chohole on
  • Kendall SearsKendall Sears Posts: 2,995
    You can also use the "Polygon Group Editor" tool to select the hair polys that are poking thru and make them invisible.
    Kendall
    Kendall
    Oh yeah I use that and never thought of doing that for hair Kendall. I am going now before I look more stupid....what you say too late. LOL
    edited July 2012
    Kendall
    I need to make a note here. If using the PGE and you need to save the results, don't use "Polygon Visibility -> Hide Selected" as this will not be retained across DS4 sessions. If you need the "hides" to be persistent then use "Polygon Assignment -> Create Surface from Selected..." to create a new Material Group. Then you can assign all of the other polys to this same group. From the surfaces tab, set the Opacity to 0% and you've now permanently set those polys invisible for that scene.
    Kendall
    Post edited by Kendall Sears on
  • larsmidnattlarsmidnatt Posts: 4,511
    Kendall
    Kendall
    Thanks so much for this, I just happened to need this today and it works like a charm. I actually never used the PGE until today but I was able to find it in the menu and follow your steps quickly.
    Thanks again.
  • Mr Gneiss GuyMr Gneiss Guy Posts: 462
    edited December 2013
    Holy cow. I've been doing things not just the hard way, but the stupidly hard way. I guess you can learn something new even when you are an old codger. Thanks, Kendall!
    I can't believe I didn't see this originally, it would have saved me so much hair pulling (pun intended).
    Post edited by Mr Gneiss Guy on
  • JaderailJaderail Posts: 0
    Tip: Got a Grass prop? Got Grass through your figures feet? Ta Da. PGE works here also.
  • Blackbirdx61Blackbirdx61 Posts: 300
    Holy necro thread batman,
    Seriously, I found this thread this morning, at its been a great help getting a Top Hat to work well with my Figures Gothic hair,
    but there seems to be no simple way to undo hiding a given polygon once its hidden, say a piece of the hats band next to a piece of the hair poking through.
    Any guidance would be appreciated.
    http://www.anar-mura.com/sketchbook/2014/Claudia_v4GothicHairTopHat..jpg
