Path to Greywood - Getting errors when loading, help !
Hi
I'm having issues when loading Path of Greywood(new product), I keep getting texture error messages (see screenshot).
Is there any ways I can fix this or a refund is the best way to go ?
Thanks
  • I'd first try reinstalling.. and see if that helps.. obviously the product should work, so if theres any issues we'll jump on getting it fixed.
  • Hmm I've pulled it down.. and see the same thing. So could be an issue with the zip, or something else. I'll ping QA now.. and hopefully a fix will be up stometime today.. apologies!
  • Bunyip02Bunyip02 Posts: 9,264
    Had the same problem, I tried manually loading the textures, but since there were so many I renamed the texture files. Also one of the trees is missing a data dsf.
    Filed a ticket to get it fixed.
    Thank you for the help, it is appreciated.
  • Had the same problem, I tried manually loading the textures, but since there were so many I renamed the texture files. Also one of the trees is missing a data dsf.
    We're on it :)
    edited October 2019
    Carrara render. Bushes are not the same location as the DAZ Studio version - Carrara uses replicators instead of instances so I hacked away to get something nice, also added a couple of Howie Farkes trees.
    1600 x 927 - 3M
    Post edited by Bunyip02 on
    edited October 2019
    We're on it :)
    Thanks Jack, update in DIM, worked fine with no missing errors after install !!!!
    2272 x 1035 - 2M
