How can I remove some violet strips?
lord Adamlord Adam Posts: 125
Hi guys!
Last time when I render a picture in CARRARA PRO 8 I've got a problem with one thing... How can I remove a violet strips form victoria's body? I know how to do it in Daz Studio 4 (I need to load a special texture for upper body) but I think in Carrara that thing should look different. Thank's for any help, I'm still on the start with 3D animation - Journey...
    Only way I know is to load a different texture. The bikini is painted on to the default tex.
  • Richard HaseltineRichard Haseltine Posts: 108,932
    If you go to Pose>DAZ's Victoria 4>Materials>Sample res (I think, something like that) there should be an AllNaturalNG pose that will replace the bikini with skin. If you are using a Carrara materials set for the base V4 you may need to check to see if there is an equivalent file, if not all you should need to do is change the torso map on both affected areas while leaving everything else in the material unchanged.
  • lord Adamlord Adam Posts: 125
    Ok, finally I have found all neded textuers manually...
    DAZ Studio helped me to find all skin textures from specific folders on my hard disk!
    Thanks anyway!
    616 x 1073 - 61K
