Is it possible to have the tattoos from Maxx HD - The Brute 8 on the Shang or Novak base skin?
edited October 2019 in New Users
[Is it possible to have the tattoos from Maxx HD - The Brute 8 on the Shang or Novak base skin?] I've been trying to get those sweet tattoos to work on my character with either the Shang, Novak, or Ren skin bases. He ends up turning weirdly transparent (and pretty goofy) only on his torso with all skins. I tried to apply all mats for Maxx as well and it happened over his entire body. I'm a complete noob, please be gentle, but is there a way to fix this? What am I doing wrong? First pic is with tattoos applied on the Shang base and the second is how he looks normally.
Thank you!
  • Sounds as if th tattoos are designed to apply to a GeoShell - select the abse figure, Create>New Geoemtry Shell, select that, and apply the tattoo material preset - does that look better? You may need to adjust the Offset parameter for the shell if there's an obvious shadow under the tattoos.
  • scorpioscorpio Posts: 8,533
    Maxx's tatoos use a Layered skin shader, just apply the tattoos to the skin you want to use them on, remember they don't show until you render.
