Unable to complete New Yeti Download
Has anyone been able to download and install this figure?
Not yet, the download keeps failing just short of 100%, trying again as I type.
Update, it failed again.
It's failing for me too. Both in the Downloader and manuel.
If you get a failed download it is best to thoroughly clear your browser cache before you attempt to download again, as the failed download will often stick in your cache and cause subsequent attempts to fail at the same point
Clearing browser cache does not work
clearing cache didn't work for me either.
No luck using DIM but I have managed to download it manually and it seems to have installed correctly, looks like there is an issue with the DIM version.
I took a look at my Daz installer log and this is the message that is being generated when attempting to install the Yeti files:
WARNING: Network Error while downloading to file "E:/Users/Public Documents/DAZ 3D/InstallManager/Downloads/IM00061551-01_YetiHDforGenesis8Male.zip.{0d338ced-9206-c190-6298-08c85fa323f8}.part":Could not complete download, file size does not match; 216688037 != 216007642.. Temporary file removed.
I'm guessing there is some sort of curruption in the referenced download file and the intall fails when the checksums do not agree. Definitely worth pinging DAZ customer service about.
