lower teeth pop out when making genesis smile, and whats a faster way to save a pose?
Hi!
I`m just starting out with Genesis, gone through the instructional materials and getting some good work done with Genesis,
enjoying the lighting and posing tools, however on working on the face now the "simple smile" at .83 pops the lower jaw teeth out, unless I bloat and swell the cheeks with "cheeks balloon pucker". Which I don`t want to do as it makes the face look childish like.
i`ve tried moving the jaw in but it doesn't work. Anyone else overcome this?
I want a full smile on the face but the lower teeth/bone pass through.
Also is there a faster way to save poses besides the icon on the horizontal bar which makes you go through a series of steps of naming and choosing a folder each time, is there an auto-name and pre-selected folder option i`m missing?
cheers,
I just loaded Genesis 1, selected the Head checked ALL my expressions and I have nothing named Simple Smile. What exactly are you doing and to which figure?
I`ve attached 3 screen caps.
I meant "smile simple"...
Cheeks and Jaw parameters house the "cheeks balloon pucker" and the "mouth" parameter contains "smile simple".
With balloon pucker set to 0, the teeth come through in a smile. It hasn't been programmed to stretch around the teeth. I don`t want to bloat the cheeks to compensate, it makes the model fatter in the face and looks younger than the character I`m intending to design.
I`m using the latest Daz3D, 4.6 with Genesis.
I'm thinking you might have a OLDER version of Genesis installed. Here is my Fully updated DAZ Studio 4.6.1.33 full Release version with same settings applied to the Default Genesis at full updates.
Did you EDIT the mouth of the figure Before you selected the head and applied the smile?
What happens for you with "mouth open" and "mouth open wide" at 1.00?
and "mouth corner up" at about .5
(including smileSimple at 1.00)
can you post a screen cap of this combined result.
No I haven`t made any structure changes to the face/jaw.
The sliders should work in unison with no bones showing through as part of the design.
ok i`m using 4.6.0.18, thats not the latest then, will the upgrade also install the new genesis?
Will I lose the custom settings I have saved?
I`ve looked on the software for an update button and can`t locate one, and nowhere on my account login does it offer an update..
how do I do this?
