missing arm
RayKatRayKat Posts: 30
ok I'm going to cry soon.I've been working on this vharacter.it's 2 v4.2 morphed together for jepes jewels.I was working on adding things doing eyes etc when i happened to be checking things out and saw thisblank spot that magicaly appeared right around her left elbow .Can any one tell me how to fix this...and before you tell me I'm screwed please be aware if you do i will end up throwing my vomputer out tmy window.any help would as always be much appreciated.I don't know what i could have done to cause it.I was poking around in various plaxes like file and edit but DAZ DOEESSNT GIVE YOU A MANUAL THAT EXPLAINS WHAT ALL OF THAT STUFF MEANS and i dont want to start screwing things up even more..Seriously man daz needs to get a damned manual so i know what a zerov figure is or any of the other stuff that is probably really helpfull...there are sov many places in thr edit section and file section...It behooved me how they spent ZERO time in making a manual.HEY DAZ you guys should head over to pixologic and check out the manual for zbrush...thats how to do it
Sorry but daz is starting to piss me off because tey make it so togh to be able to help yourself.If i had a manual I would have figured this out on my own...any way i could use the help/....tthanks...Im hoping theres a screen shot attached to this...there should bw anyway...check it out
raykat
    There is a user guide here : http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/start have you seen that, and the forum thread as well - http://www.daz3d.com/forums/discussion/32246/
    You image is very small, and difficult to see, you can post an image to the forums here directly by using the Browse button just below where you write your post.
    From what I can see, it looks like a transparency issue. Select that surface using the Surface Selection Tool ()Alt+Shift+M, and check the Surfaces tab for the Opacity channel.
  • RayKatRayKat Posts: 30
    Thanks for the response.Yeah that's what pisses me off.I kind of figured it was something stupid,it's just not having all the tools you need to figure everything out.As far as the users guide goes.Is there a new one?I've checked ot the old referenceguide and users guide and the problem with those is a lot of things were written years ago and are pretty out of date.
    It was the same way when i was trying to learn top load content manually.There were 10 different people telling you 7 different ways of doing it and then some other peson tells ya "Nahh they're all wrong ya do it like this." I need to talk to the person who wrote the little tutorial of how to setting up content who did it in a totally different et unique kind of way where she or he only used 2 folders for everything and the way it was set up was rad.I think the persons name was Jakie.
    Any way I thank you for your help.I just get really frustrated with DAZ a lot and it's whavky way of doing things.I ended up just starting from scratch and just finishedv so I'm all good.It was just a massive waste of time and turned it into more of a chore than fun.
    thanks again
    raykaT
    The links that Jimmy gave you are for the new guides which were released just a couple of weeks ago.
  • Richard HaseltineRichard Haseltine Posts: 109,570
    Yes, the User Guide is new (last month).
    Have you tried rendering? That looks very much like a preview-only issue.
    you both rock.Thank you so much for the heads up,I'll check rm out right now.My printers going to hate you boththanks again raykat
